Keeping Finish Out Of Body Holes
http://www-.luthiersforum.com/forum/viewtopic.php?f=10123&t=50369
Author:  old_picker [ Tue Feb 27, 2018 5:46 pm ]
Post subject:  Keeping Finish Out Of Body Holes
Haven't posted here in a cockatoo's age
About to finish another guitar in lacquer and again thinking on how to keep the finish out of the bridge and stop bar holes. I have tried tissue, thin scrunched plastic, Plasticine and just shot lacquer straight over them and cleaned up after.
Inevitably I will lose finish when pulling the fill or have it shatter when tapping in the bushings. Worst thing is time consuming lacquer repairs putting a barrier between the customers cash and my wallet.
Any one have a tip?
greatly appreciated and thanks in advance
Author:  B. Howard [ Wed Feb 28, 2018 8:40 am ]
Post subject:  Re: Keeping Finish Out Of Body Holes
I finish over them and press the bushings in hot. The heat will keep them from chipping the finish.
Author:  dzsmith [ Wed Feb 28, 2018 12:47 pm ]
I install the bushings slightly below the body surface before finishing, and cover them with tape.
I use a Dremel to create a step for bushings that have a lip.
Author:  old_picker [ Wed Feb 28, 2018 6:21 pm ]
the step is done before finishing or after finishing?
Author:  dzsmith [ Wed Feb 28, 2018 9:21 pm ]
Before finishing.
Author:  old_picker [ Wed Feb 28, 2018 11:47 pm ]
Love to know how you get a dremel to cut a nice even step like that - I was thinking on using a 19mm countersink bit. Currently masking up and about to start on shellac as pore fill. This one is in korina and the grain is very open which takes a lot to fill out. So I have a few days before I start laying down lacquer coats to get this right. I drove the stop bar studs just below the surface and I will tape them off as per your suggestion.
btw that looks like a very nicely built instrument and the burl is quite stunning [:Y:]
Author:  dzsmith [ Thu Mar 01, 2018 9:48 am ]
I mounted the Dremel in a router base, and routed it out by hand.
Author:  old_picker [ Thu Mar 01, 2018 5:06 pm ]
ok good hands i reckon - i tend to be less trusting of getting a neat result
i will do it like that but mount a 16mm mdf on top with 2 x 14mm holes @74mm centers punched through as a bit of a guide
Author:  fumblefinger [ Thu Mar 01, 2018 11:02 pm ]
You might give these a try. A reverse spot face tool.
https://www.yardstore.com/drilling-and- ... se-cutters
Author:  rlrhett [ Fri Mar 02, 2018 10:34 am ]
Keeping Finish out of body holes?....
Pants and a good respirator.
